TwinTurbo.NET: Nissan 300ZX forum - Check battery connection.. don't visually check it..
Subject Check battery connection.. don't visually check it..
Posted by KongZTT GT28RS MD on April 11, 2011 at 8:35 AM
  This message has been viewed 102 times.
In Reply To car will not start or even crank! posted by evanm69 on April 10, 2011 at 07:34 PM
Message Take the terminals off.. clean them.. and put them back on tightly.
You may have to use battery post shims if it still feels loose AT ALL.
Did you check the fuse next to the battery? Its a Green 20amp fuse for the ignition circuit (small fuse box next to battery on LHD Z's. Has a row of about 5 fuses, they aren't regular fuses, they are larger that plug in)
It sounds like a connection problem. Check grounds on the chassis-->battery.
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
